Pepperl+Fuchs
Autonomous wireless sensor
With the Wilsen.sonic.level, Pepperl+Fuchs presents an ultrasonic level sensor that can be used to determine filling heights and filling and level levels.
© Pepperl+Fuchs
The measured values are recorded at regular intervals and transmitted to the Internet. The autonomously operating wireless sensor is battery-operated and can therefore also be used away from any power supply infrastructure. The sensor from Pepperl+Fuchs detects the fill or level using ultrasonic distance measurement; it does not matter whether the medium to be detected is a liquid or a fine or coarse granular bulk material. Thanks to its adjustable sonic beam width via mobile app and various evaluation and filter methods, the sensor enables reliable measurement even in dusty and dirty environments as well as in narrow shafts and, for example, containers with struts or other installations.
In addition to the fill level information, further data such as the temperature at the installation site, the battery status and optionally the geoposition are recorded cyclically at the set interval. All data is then transmitted wirelessly from the sensor to the Internet using the globally standardized LoRaWAN technology. Both public and privately operated LoRaWAN networks can be used for this.
Pepperl+Fuchs
Safe via ultrasound
Ultrasonic sensors with safety certification in accordance with EN ISO 13849 category 3 PL d have so far been the exception rather than the rule. However, they offer a number of advantages, for example for cooperation between humans and robots.
PCB Synotech
Cable easily replaceable
The triaxial ICP sensor model 356A06 from Synotech offers a measuring range of 1000 g with a sensitivity of 5 mV/g and, according to the supplier, a wide frequency range for many types of vibration tests.
Pepperl+Fuchs
From the sensor to the cloud
One of the 'magic formulas' in the Industrial Internet is 'continuous information flow'. However, the installed base of production cannot be 'converted' as easily as business software. Instead, the migration must integrate different components.
