PCB Synotech
Cable easily replaceable
The triaxial ICP sensor model 356A06 from Synotech offers a measuring range of 1000 g with a sensitivity of 5 mV/g and, according to the supplier, a wide frequency range for many types of vibration tests.
The high shock protection and its hermetically sealed titanium housing make the sensor robust despite its small dimensions. Thanks to the mini 4-pin connector, the cable is easy to replace and the sensor is easy to apply. With a weight of 1 g, this model is particularly suitable for measuring small components and prevents mass loading effects.
The Synotech sensor can be operated with any ICP power supply that is supplied with 18 to 30 V(DC) and 2 to 20 mA constant current.
