Mushroom
Secure hold for the moving belt
For the protection of conveyor systems and machinery, Pilz is expanding its range of position and proximity switches with the compact draw-wire switch PSENrope mini.
The space-saving version of the 'PSENrope' pull-wire switch enables functional processes to be switched off manually. The mechanical emergency stop function on 'PSENrope mini' can be triggered both at the integrated emergency stop button and at any point by pulling the rope. Thanks to the rope length of up to 30 m, even extensive applications can be operated and secured with just one rope pull switch. The pull-wire switch variants with straight or angled heads contribute to flexible installation. If the machine design requires concealed installation, the variant with integrated reset button is used.
The robust metal or plastic housing to IP67 makes the mushroom pull-wire switch suitable for both indoor and outdoor applications with ambient temperatures from -30 to +75 °C.
