Products of the year 2023
Andrea Gillhuber,
Safety - The winners
The winners in the Safety & Security category demonstrate the broad spectrum of functional safety: from risk assessment to emergency stop switches.
© WFM
3rd place: Georg Schlegel - IP69K Combitast emergency stop
© Georg Schlegel
3rd place - Georg Schlegel
The IP69K combi pushbutton emergency stop is designed for mobile machines and special vehicles that are exposed to difficult environmental conditions. It was developed in a joint project between Data Panel and Schlegel. The overmolded emergency stop features protection class IP69K on the front. IP65 protection is guaranteed on the rear when the cable is connected. On the inside, a Gore seal ensures that no moisture can penetrate while allowing air to pass through. More...
It is indispensable in every production facility, in every laboratory, even in large construction machines - the emergency stop switch. But this almost inconspicuous electromechanical component contains a great deal of innovative power, as the winning product from Schlegel shows. Kurt Blank, Head of Development & Design (Mech.), and Torsten Singer, Product Manager at Schlegel, provide some insights.
2nd place in the Safety & Security category
2nd place: Schmersal - DHS-150 door handle system
© Schmersal
2nd place - Schmersal
Schmersal launches the ergonomic DHS-150 door handle system for the 'AZM150' solenoid interlock. It eliminates the need for a separate door handle and is suitable for machine enclosures and fencing as well as for standard 40 mm wide aluminum profiles. The door latch is particularly suitable for heavy swing doors and can be used in harsh environmental conditions. The actuator is pre-positioned by the latch in the DHS system and thus, according to the supplier, retracts optimally into the device. More...
1st place in the Safety & Security category
1st place: Machinery Safety Evaluation
© Mushroom
1st place - Pilz
With Machinery Safety Evaluation (MSE), Pilz offers a service for evaluating the machinery safety of existing machinery. It includes the evaluation of machinery in a production plant on site with regard to the applicable safety and conformity requirements. Not only are the applicable standards and directives at the place of use or destination of the machinery taken into account, but also the customer's internal company specifications on request. More...
Pilz is regarded as a safety expert. In addition to components, the company also offers services in this area. Safety assessment for plant and machinery is one of them. And this is in demand internationally, as Jürgen Bukowski, Senior Engineer at the International Service Group by Pilz, knows. In this interview, he explains the challenges the team has to overcome.
Schmersal
Variants for other fieldbus systems
Schmersal is launching two new versions of the 'Safety Fieldbox' on the market. This means that the box can not only be integrated into systems with Profinet/Profisafe as before, but is also available for Ethernet/IP with CIP Safety and Ethercat...
Mushroom
Cool management of hot spots
Burner management systems for the fully automatic operation of a burner system have a complex structure. Due to the high risk potential, strict regulations apply to avoid safety-relevant process conditions. How can these be implemented and complied...
Schmersal
ToF camera for automation technology
Schmersal is launching a 3D camera for the automated acquisition of digital process data in real time. The 'AM-T100' time-of-flight camera (ToF camera) generates 3D depth images with millimeter precision using a Sony DepthSense sensor.
Mushroom
Error? Unacceptable!
High-end systems from Brainware Solutions check the quality features and functions of door panels at an automotive supplier. Integrated into a production line, a test run of the black box takes 23 seconds. The operating and safety concept is...
Georg Schlegel
Suitable for rail transport
The Schlegel charging sockets are available in three versions, each with two USB ports from the combinations of USB-A and USB-C: A/A, A/C and C/C. The USB-A port delivers up to 2.4 A, the USB-C port up to 3 A charging current at 5 V output voltage.
