Schmersal
Variants for other fieldbus systems
Schmersal is launching two new versions of the 'Safety Fieldbox' on the market. This means that the box can not only be integrated into systems with Profinet/Profisafe as before, but is also available for Ethernet/IP with CIP Safety and Ethercat with FSoE.
© Schmersal
The 'Safety Fieldbox' from Schmersal enables flexible safety solutions, failsafe and fast installation and, according to the supplier, a high level of process transparency. It allows the simple connection of up to eight safety switching devices via plug and play. The universal device interfaces for 8-pin M12 plugs can be used to connect a wide range of different safety switching devices such as electronic and electromechanical solenoid interlocks, sensors, control panels, light curtains or switches. Solenoid interlocks or safety light curtains only require one M12 slot, and control panels with an EMERGENCY STOP function and up to three non-safe control and signaling devices can also be connected. An integrated digital input at each device slot allows the diagnostic signals of all connected safety switching devices to be evaluated. This means that both the safety-related signals and the operational signals required for diagnostics, for example, are collected and transmitted. The user can use this information, for example, to detect irregularities such as a misalignment of the safety gate and thus enable early intervention in the event of servicing.
Schmersal
The rules of collaboration
A wide range of normative requirements apply to safe direct collaboration between humans and robots without physical separation, for example by means of safety fences. What are these and how can they be implemented in practice?
Schmersal
ToF camera for automation technology
Schmersal is launching a 3D camera for the automated acquisition of digital process data in real time. The 'AM-T100' time-of-flight camera (ToF camera) generates 3D depth images with millimeter precision using a Sony DepthSense sensor.
Schmersal
Motto "Sustainable!"
The EU Commission has presented a proposal for a new Ecodesign Regulation for Sustainable Products (ESPR), which is to become a central component of the European Green Deal. Schmersal is also already on the road to sustainability.
