Schmersal
ToF camera for automation technology
Schmersal is launching a 3D camera for the automated acquisition of digital process data in real time. The 'AM-T100' time-of-flight camera (ToF camera) generates 3D depth images with millimeter precision using a Sony DepthSense sensor.
© K.A. Schmersal
The frame rate of the ToF camera is up to 60 fps. With IR illumination and an image resolution of 640 x 480 pixels, it achieves a field of view of 67° x 51° at a range of up to 6 m. The image data is made available via the standardized GenICam data interface and can be processed with common image processing software. An Ethernet interface enables data transmission and, if required, a 24 V power supply (Power over Ethernet). The 'Consam-T' configuration software is pre-installed. According to Schmersal, it can be used to configure the camera so that it monitors complex and individually defined 3D zones. If it detects an object within these zones, digital outputs are switched. In addition, digital inputs can be used to switch back and forth between different 3D zones.
Schmersal
The rules of collaboration
A wide range of normative requirements apply to safe direct collaboration between humans and robots without physical separation, for example by means of safety fences. What are these and how can they be implemented in practice?
Schmersal
Variants for other fieldbus systems
Schmersal is launching two new versions of the 'Safety Fieldbox' on the market. This means that the box can not only be integrated into systems with Profinet/Profisafe as before, but is also available for Ethernet/IP with CIP Safety and Ethercat...
Schmersal
Machine safety - tailor-made!
Safety functions are shifting from the hardware to the software level. It therefore makes sense for machine manufacturers to work together with the safety system supplier at an early stage of new developments. The use of OEM-specific software offers...
