Products of the year 2021
Andrea Gillhuber,
Safety - the winners!
Nomen est omen: the brains behind the award-winning products were certainly delighted to receive the award in the Safety category. The winners at a glance.
© WEKA Trade Media
The 'CES-C07' safety switch and the 'ESM-CB' safety module
© Euchner
3rd place: With the 'CES-C07' safety switch and the 'ESM-CB' safety module, Euchner has a duo in its portfolio that, according to the manufacturer, opens up new freedoms in the design of safety solutions for smaller systems. Together, they are able to communicate at Industry 4.0 level. They achieve requirements up to safety function category 4 and performance level e (PLe). More...
Dr. Hannes Zipse, Head of Sales Germany at Euchner, was delighted with the trophy and explained the special features of the components in the showroom.
2nd place in the Safety category
The RFID-based solenoid interlock 'AZM40'
© Schmersal
Schmersal has launched the RFID-based AZM40 solenoid interlock, which, with dimensions of 119.5 mm × 40 mm × 20 mm, is the smallest electronic solenoid interlock in the world. Thanks to the 180° angular flexibility of the actuator, it can be infinitely adjusted to the AZM40 so that the guard locking can also be used for flaps that do not close at a 90° angle or that open upwards at a 45° angle. More...
Stephan Frick, Product Manager for Safety Technology at Schmersal, accepted the trophy and explained how a supposedly simple component plays a major role in a safe application.
1st place in the Safety category
The coded safety switch 'PSENcode'
© Mushroom
The coded safety switches 'PSENcode' from Pilz, which are based on RFID transponder technology, now offer a further solution for space-critical applications: According to the manufacturer, the PSENcode low profile actuator, which is only 3 mm high, is currently the lowest actuator in the world. The actuator complements the 'PSENcode' safety switches in the narrow or compact design and can be combined with them. More...
Martin Bellingkrodt, Product Manager Safety Sensors at Pilz, also gave an insight into Pilz's roadmap during the award ceremony.
Schmersal
Machine safety made easy
The 'System Engineering Tool' can be used to design complex cable installations for safety switchgear on machines and systems. Users can put together distributors and safety switches using drag & drop. Product Manager Udo Weber explains the...
Schmersal
Safety for set-up operations
The safety function 'Safely limited speed with safety gate open' is relevant for set-up operation or troubleshooting on machines. Below is an example of a safety solution with a redundant encoder and safety controller.
Siemens
AI classification for safety
Artificial intelligence is seen as a solution to current challenges in various areas of life. Politicians are promoting AI, but would like to assess the consequences of the technology and regulate it if necessary. The use of AI for security tasks is...
Mushroom
Extensions in the software tool
In the software tool PNOZmulti Configurator of the configurable small controller 'PNOZmulti 2' from Pilz, new function blocks are available from software version 10.13 for easy configuration of safe user programs.
