Schmersal
Reliable signal evaluation
Schmersal is launching the SRB-E-302ST safety relay module and the SRB-E-402EM output extension. The safety relay module acts as an evaluation unit for two safety sensors and replaces several modules from the older AES series.
Safety relay module SRB-E-302ST and the output extension SRB-E-402EM from Schmersal
© Schmersal
The safety relay module from Schmersal can be used to monitor common electromechanical and electronic safety switches as well as safety sensors and optoelectronic protective devices (AOPDs). Depending on the application, the module switches with the safe relay contacts or with a safe semiconductor output. Applications can be realized up to category 4/ PL e and SIL 3. Like the SRB-E-302ST, the SRB-E-402EM output extension is housed in the compact housing of the SRB-E series. Designers can use it to multiply and amplify the contacts of safe relays and semiconductor outputs. Four safety contacts, two signaling contacts and feedback contacts are available. The safety module can be used as an extension module for all safety modules and safety controllers that have feedback circuit monitoring.
Schmersal
Machine safety made easy
The 'System Engineering Tool' can be used to design complex cable installations for safety switchgear on machines and systems. Users can put together distributors and safety switches using drag & drop. Product Manager Udo Weber explains the...
Schmersal
Safety for set-up operations
The safety function 'Safely limited speed with safety gate open' is relevant for set-up operation or troubleshooting on machines. Below is an example of a safety solution with a redundant encoder and safety controller.
Schmersal
Motto "Sustainable!"
The EU Commission has presented a proposal for a new Ecodesign Regulation for Sustainable Products (ESPR), which is to become a central component of the European Green Deal. Schmersal is also already on the road to sustainability.
