Sigmatek
Andrea Gillhuber | Andrea Gillhuber,
Relay output module for the top-hat rail
The SRO 022 safety module with two safe, dual-channel outputs from Sigmatek meets the safety requirements of SIL 3, PL e.
© Sigmatek
The SRO 022 relay output module from Sigmatek expands the S-DIAS modular safety system. It can be used to switch higher voltages of up to 230 V/6 A in a safety-oriented manner.
The safety relay module for the top-hat rail has two safe, dual-channel outputs over a width of 25 mm and meets the safety requirements SIL 3 and PL e. The two outputs are used for the safety-related closing (NO) of a circuit with a permissible nominal voltage of 24 VDC/230 VAC and a maximum continuous current of 6 A.
The SRO 022 is used, for example, for switching higher power or isolated circuits such as hydraulic valves or for passing on emergency stop circuits. In combination with the S-DIAS Safety CPU, which controls time-correct communication with the safety modules via safe bus telegrams, very short response times are achieved.
Associated safety applications can be easily configured thanks to the extensive library in the Lasal Safety Designer. The safety function blocks are based on the PLCopen standard and can be easily placed using drag & drop.
Sigmatek
Real-time Ethernet portfolio expanded
A CPU module and an interface module expand the real-time Ethernet bus portfolio of the 'SDIAS' control system from Sigmatek. The CP 313 DIN rail module is a CPU with a dual-core Edge2 Technology processor for control, regulation and motion tasks.
Sigmatek
More power in the servo system
Modularity, flexibility and a higher power density are the trend in the development of new production machines. This has an impact on integrated drive technology. A modular, very compact multi-axis servo system meets the challenge.
Sigmatek
Intelligent and safe
A new generation of riveting machines relies on servo technology instead of pneumatics and hydraulics. The intelligent drive technology has increased the precision and quality of riveted joints and reduced the number of machine variants.
Sigmatek
Security is integrated
In addition to WLAN data transmission, the HGW 1033-32 hand-held operating device from Sigmatek is equipped with safety elements, a high-resolution 10.1-inch multi-touch display and three rotary encoders.
