HMI solutions
Quelle: GTI-control | Lukas Dehling,
Scalable in the range of applications
Procon-Web from GTI is a web HMI that can run on different platforms - from embedded systems to virtualized Windows servers - and also scales in the range of applications from simple HMIs to complex control systems.
© GTI-control
According to the manufacturer, all types of applications can be consistently covered with one engineering tool and are compatible with each other. This means that cost-effective web HMIs can be hosted within a controller on a project basis and powerful data processing-heavy multi-user applications can be used on classic IPCs or virtualized servers. GTI presents the new version with the option of compatibility with Codesys, B&R controllers or Linux (e.g. Raspberry Pi).
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
