ifm electronic
Flexible Visualization with LED Strips
ifm is launching LED strips that enable innovative visualizations. The strips, available in lengths ranging from 250 mm to 5,000 mm, consist of up to 320 LEDs, each of which can be individually controlled for color and brightness.
© ifm electronic
Since the flexible LED strip is fully encapsulated in plastic using a special extrusion process, it meets the IP69K protection rating. This makes the LED strips suitable for applications in the food industry as well. Should an LED ever fail, the rest of the strip continues to function without restriction thanks to an integrated bypass system. The flexible strips can also be mounted on curved surfaces. They are controlled via the “DP1617 Controller,” which allows the user to select from predefined operating modes. In Segment Mode, individual segments of the strip can be defined and then controlled independently. Run Mode can simulate a moving light effect. Bargraph Mode displays values as a bar graph, while Position Mode can clearly indicate specific positions.
Evotron
Multicolored area light
Evotron has introduced the 'A82x82' series of diffuse monochrome and multicolored surface lighting. New features have been added to the implemented 'Lumisens' technology.
Wenglor
Precise illumination
The new spotlights from Wenglor with lockable zoom lens for a variable beam angle in the range from 4 to 26 ° with constant homogeneity enable a pinpoint lighting situation.
Basler
Modular board level camera
With the 'dart M', Basler is launching a customizable board-level camera with GigE interface that adapts to the installation situation and existing electronics of the customer application thanks to its modularity and design.
