Virtual HMI
Quelle: Spectra | Inka Krischke,
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is still necessary for the operator or technician to be able to call up and set the process data at any time.
© Spectra
This process is made easier and faster with the help of platform-independent remote access. The virtual HMI models of the 'UniStream PLC' series from Spectra enable precisely this simple operation. They no longer have an integrated touch display, but behave in exactly the same way for the programmer as the models with an integrated touch display. All display and operating elements are completely defined and parameterized within the 'Unilogic' development environment. Using an app available for all operating systems, the user interface of the PLC can be displayed on a smartphone, tablet or PC. The UniStream Virtual HMI series is available in Classic, Standard and Pro versions, which differ in terms of I/O expandability, interface options for communication with other systems, SD card support and the scope of special software functions such as web servers or PID control loops. If a touch display is still required directly on the system or machine, the series can be retrofitted with a display or can be connected to a display via Ethernet.
Siemens
The Glass@Service project
A consortium of six companies and institutions led by Siemens has spent the last three years researching augmented reality (AR) in industry. - The results of the Glass@Service project.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
