Maintenance service
Quelle: ABB,
Forecast remaining useful life
ABB is expanding the Ability Condition Monitoring service for the drive train, which connects drives, motors, pumps and bearings, with an option for condition-based maintenance of drives.
© ABB
The software provides early warning of unusual operating conditions that could lead to the premature failure of a drive with the corresponding components. Cloud-based algorithms and statistical analyses are used to determine the stress on the components and calculate their remaining service life. If a failure is predicted before the next scheduled maintenance, measures can be initiated to prevent an unplanned downtime. In some cases, the new service may also reveal that the drive components are subject to less stress than usual. In this case, the regular preventive maintenance intervals can be extended to achieve higher productivity and cost reductions. As a first step, ABB's condition-based maintenance service is available for air-cooled ACS800 and ACS880 series drives. The accuracy of the predicted remaining service life depends on the specific application. In many cases, however, the failure of drive components can be predicted one or even two years in advance.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
