Industrial PCs
Quelle: Noax Technologies,
Flexible thanks to support arm system
Thanks to the combination of industrial PCs from Noax with support arm systems, the workstation can be optimally designed.
© Noax Technologies
This means that the configurable support profiles from Rittal can be adapted on site and depending on the situation - whether cantilever arms, wall brackets or floor mounting, whether fixed or swiveling. The multi-touch technology (PCAP) with functionality right up to the very edge enables error-free data input. Ergonomic working is supported by the reliable operability of the industrial PC with work gloves. In addition, the extremely robust front made of hardened safety glass with integrated LED multifunction keys can be customized via the 'nSmart' user interface.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
