CAE software
Quelle: AmpereSoft | Lukas Dehling,
Automated functional sequences
AmpereSoft presents the new version of its CAE tool system. A new fluid and P&I flow diagram as well as updated symbol tablets are now part of the Proplan detail engineering tool.
© AmpereSoft
In addition, the software's extensive automated function sequences are designed to reduce engineering time for users. ProPlan is fully connected to its sister solution Matclass, a tool for managing and maintaining material data. The tool uses the eCl@ss-Adcanced structure for this purpose. Another new feature is the Temperaturecalculator, which is designed to support planners with thermal calculations in the enclosure. The calculation tool takes into account all equipment-related and load-dependent variables in accordance with DIN EN 61439-1 fully automatically. The QuotationAssistant, on the other hand, helps planners to prepare quotations and tenders within engineering projects. Here too, the calculation of individual cost components is automated.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
