Pepperl+Fuchs
Transparency in the process industry
Better insights into data from sensors and actuators are at the heart of tomorrow's process automation. Ethernet APL plays a decisive role in this. However, there are a number of factors to consider when introducing it.
Ethernet via a two-wire cable for the process plant field
© Pepperl+FuchsTwo established technologies come together in the digitalization of process automation: Ethernet and shielded, twisted pair cables. They enable a flat, fast and fully networked infrastructure that is attracting interest from suppliers and users alike.
However, Ethernet in process plants initially raises numerous questions: What happens to the existing cabling? What cable lengths are achievable? What tools are available for accessing the instrumentation? What about intrinsic safety in hazardous areas?
Performance data and infrastructure
Four aspects must be precisely defined in order to create a completely open infrastructure that offers the interoperability that users expect from Ethernet.
Firstly, the standard for single-pair Ethernet IEEE 802.3 cg defines data communication as 10BASE-T1L. The bandwidth of 10 Mbit/s allows, for example, the updating of radar curves every two seconds and supports users during time-critical phases, such as those that can occur during the commissioning of tank sensors. This bandwidth is also crucial for automatically downloading, saving and restoring device configurations. This significantly reduces the risk of human error.
The Ethernet APL port profile specification also defines the power supply. The planner simply selects switches and devices with matching power classes. For example, Ethernet-APL defines standard power levels for intrinsically safe device connections such as Ex ic IIC for Zone 2/Div. 2 or Ex ia IIC for Zone 0 or 1/Div. 1.
Thirdly, the Ethernet APL port profile specification defines connections, cables and accessories such as overvoltage protection. Changes to the cable infrastructure are quite complex and costly. It is therefore crucial to make the right decisions right from the start. The table on page 48 shows standardized parameters for Ethernet APL that are compatible with fieldbus communication technologies. It is advantageous if planners and system operators specify parameters from the outset that are tailored to the requirements of the respective process system. Reliable communication requires shielded two-core type A cables. If the existing cables are to be used to set up an Ethernet network, it makes sense to ensure that they are compatible with the specifications (see table) in order to avoid risks. This check is simple, as Ethernet-APL only requires two wires and not four or even eight. It is possible with standard tools and can be carried out by installers and office colleagues.
One provider has even tested 10 Mbit communication via an unshielded twisted pair cable. However, this was done under laboratory conditions - in practice, this is strongly discouraged. With unshielded cables, communication is not protected against crosstalk and electromagnetic interference. The required stability of communication is therefore not guaranteed in the long term.
The fourth aspect is intrinsic safety, where a new chapter of the well-known standard for explosion protection defines the same simple planning and validation approach that users of FISCO are familiar with (IEC TS60079-47, 2-WISE).
Direct line to each field device
Ethernet-APL Field Switches allow point-to-point connections to field devices according to standardized track definitions. The maximum cable length is 200 m with optional intrinsic safety. The 'FieldConnex' series from Pepperl+Fuchs also includes Ethernet APL switches for DIN rail mounting. Robust housings allow installation in the immediate vicinity of a field device in Zone 2 or a remote I/O station. Power supply and communication are segmented via point-to-point connections, allowing for a simple topology. Even with repeated connection and disconnection - for example during maintenance work on or when replacing instruments - this infrastructure is highly resistant to interference.
Replacing a field device is simple: as soon as the new device is connected, it is automatically switched on and recognized and identified by the asset management system. This allows asset management systems to automatically restore the configuration. Standard Ethernet cables can be used between the control center and the distribution box. With the help of fiber optic cables, distances of up to 2,000 m can even be bridged. Standardized Ethernet concepts apply for redundancy, such as the Media Redundancy Protocol (MRP), which is also used for Profinet.
A common network structure
Process plants are often in operation for several decades. During this time, the technology of the field instrumentation used often changes. Ethernet provides the basis for connecting different generations of technology under a common network structure. Appropriate protocols allow engineering independent of the data source.
Rail field switch for 8, 16 or 24 devices from FieldConnex. The connection to the process control technology with redundancy can be made either via copper or fiber optics.
© Pepperl+FuchsThanks to Ethernet-APL, communication with field devices can be combined via Profibus PA and Profinet. Communication, power supply and explosion protection can also be operated within the same infrastructure and according to the same technical concepts. At a time when device manufacturers are only just starting to provide Ethernet APL-capable products, this limits the risk, especially for first-time users. Ports with dual function can automatically recognize which device type is connected.
The PA profile standardizes the representation of similar devices from Profibus PA in Profinet: process values, basic configuration and diagnostics. These are defined in the same way for each measurement type, regardless of manufacturer, model series or device size. Similar behaviour in every work step eliminates manual effort and minimizes risks when handling the instrumentation.
© Pepperl+FuchsWith the PA profile, Ethernet-APL devices and controllers have a compatibility mode for Profibus and Profinet technologies. This is a single device description that is supplied with controllers, network components and field devices. For the user, this means that several measured values per device can be configured identically across manufacturers and products. There is no dependency on the brand, model or size of a particular device. For example, a pressure transmitter provides the values for pressure and media temperature in the same way regardless of the manufacturer. This procedure is therefore recommended for around 80 % of all standard measurements.
For hazardous areas, there are robustly designed LB/FB remote I/O systems that allow digital communication to be extended into the hazardous area. They are connected to the control room via the same infrastructure, power supply and communication and allow access to devices with a 4 to 20 mA interface. Additional information from the field instrument can also be integrated via HART, for example the device status or historical data. As individual HART masters are used for each remote I/O output, access is instantaneous.
Intelligent use of data
The sensors and actuators installed in process plants around the world already provide a wealth of information that can be used intelligently. Using protocols such as Profinet, Ethernet I/P, OPC UA and HART-IP, this information can be seamlessly integrated into the Ethernet communication world. This means that new methods can be used to monitor and optimize the process flow in order to increase efficiency. It also creates an information basis for implementing proactive maintenance procedures. The following steps should be taken to create the key prerequisites for a future-proof network infrastructure with minimal risk:
- Evaluate Ethernet APL as the main infrastructure
- Use of fieldbus systems with profile data
- Check existing cables for suitability for Ethernet APL
- Use cables according to Ethernet APL specification
The author: Andreas Hennecke is responsible for product marketing at Pepperl+Fuchs in Mannheim.
© Pepperl+FuchsFuture improvements and extensions are then possible without restriction. Specific information, case studies and best practices for planning, installing and operating Ethernet APL networks can be found in the Ethernet APL engineering guideline. When building new process plants, an evaluation should also be carried out according to Ethernet APL aspects. By combining switches with remote I/O systems, communication with any type of device is guaranteed. Type A cable according to the Ethernet-APL specification ensures robust communication. Ethernet-APL enables the connection of future devices to the fieldbus technology. Profile-based communication makes operation, maintenance and device replacement far easier than with the 4-to-20 mA interface, as neither PV scaling nor setting device addresses is required.
