ODVA / OPC Foundation
Andreas Knoll,
OPC UA and CIP devices should cooperate
The ODVA and the OPC Foundation have set up a working group to develop an OPC UA Companion Specification that regulates the interaction between OPC UA and the Common Industrial Protocol (CIP).
Dr. Al Beydoun, ODVA: "The time is ripe for the OPC UA Companion Specification to ensure that EtherNet/IP meets the requirements of Industry 4.0 and IIoT."
© ODVA
The collaboration between the ODVA (Open DeviceNet Vendors Association) and the OPC Foundation should lead to reliable and secure communication between devices that are part of a CIP-capable industrial control system and other OPC UA-capable applications. Communication between CIP devices and OPC UA devices as well as with cloud services and enterprise software should be possible. General tasks required for the management of cloud gateway devices will be defined; CIP devices will have unrestricted access to important cloud services. "The transfer of process and control data from EtherNet/IP devices to OPC UA servers will enable valuable information from the factory floor to be made available at the edge and beyond - including in the cloud - for enterprise-wide analysis," explains Dr. Al Beydoun, President and Executive Director of ODVA.
The OPC UA Companion Specification will map CIP objects to the corresponding OPC UA information models and profiles - and vice versa. Data transfer to and from the cloud and from EtherNet/IP to OPC UA is made possible by the CIP devices providing useful information such as discovery, identity, diagnostics, status and parameters. The fact that critical process data can be easily transferred from EtherNet/IP to OPC UA will significantly reduce the effort required to access higher-level systems such as analytics, ERP or MES. The OPC UA Companion Specification will ensure that the data is available to business and IT systems in the right form for rapid trend analysis and insight generation.
A joint working group made up of members of the ODVA and the OPC Foundation will work on identifying critical device-to-cloud use cases, such as the feedback of warranty costs to production variants. In parallel to the joint development of the OPC UA Companion Specification, CIP and EtherNet/IP will be extended by ODVA SIGs as required to ensure that OPC UA can understand all relevant data without additional effort for end users. "The time is ripe for the OPC UA Companion Specification to ensure that EtherNet/IP meets the requirements of Industry 4.0 and IIoT," emphasizes Dr. Al Beydoun.
The collaboration between ODVA and the OPC Foundation will ensure the scalability and interoperability of critical device information across the enterprise. Most importantly, the OPC UA servers will be able to map and represent CIP objects and provide the services that enable the establishment of a connection and exchange of messages between OPC UA applications and EtherNet/IP. Ultimately, the OPC UA Companion Specification should be able to map CIP objects to the required information models and profiles.
TSN
A common test plan for the industry profile
Avnu, CLPA, ODVA, OPCF and PI are cooperating to generate a standardized test plan for the emerging TSN profile IEC/IEEE 60802 for industrial automation. All the organizations will be able to test their products for conformity with the new profile.
Ethernet-APL
The standard is
Standardization work has been underway since 2015 and the intrinsically safe physical layer designed for 2-wire cables called Ethernet-APL is now available; the first products are ready for the market.
ODVA
HART devices on Ethernet/IP
At the trade fair, the ODVA announced the publication of further developments to the Ethernet/IP specification. These show how devices based on the HART communication protocol can be integrated into an Ethernet/IP architecture.
