IoT gateways
Quelle: SSV Software Systems | Inka Krischke,
Four remote maintenance tasks in one device
With the RMG/941, SSV has developed an IoT gateway that combines four industrial remote maintenance tasks in a compact DIN rail housing.
© SSV Software Systems
In addition to the classic VPN remote access interface for manual maintenance tasks, component, machine and system connection to the IoT platforms of the market-leading cloud platforms via CoAP, MQTT, REST or OPC UA is supported in particular. Real end-to-end cyber security is available from the sensor to the actuator. For example, sensor readings at one end can be provided with a digital signature using a public key infrastructure (PKI), which actuators at the other end can verify using an X.509 certificate and a public key. This guarantees the authenticity and integrity of the data for distributed applications. In addition to integrated machine learning functions for anomaly detection through permanent real-time analysis of sensor data, the IoT gateway has a modular construction kit for the secure remote software update of OT assemblies. The device is available in three different hardware variants. Depending on the variant, the connection to the internet can be established via Ethernet, 4G or NB-IoT mobile modem. All common IoT and cloud protocols are supported. The cyber security functions are based on OpenSSL.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
