Strain reliefs
Quelle: Igus | Inka Krischke,
Makes cable ties superfluous
Igus offers a strain relief system for energy chains in which cables and hoses are inserted into a honeycomb and then firmly sealed. Now a further developed system is coming onto the market to replace the previous variants.
© Igus
The CFU honeycomb strain relief replaces the cable ties frequently used in the industry to date: whereas previously each cable was fixed individually to the energy chain, with the new solution the cables and hoses are simply inserted into the honeycomb and sealed. The outer walls of the honeycomb cavities gently and firmly wrap around the cables. The honeycomb is quick to install and flexible, as new cables can be easily inserted or replaced. The further improved strain relief combines a compact design with simple and flexible filling. The flush connection with the energy chain connection element means that the strain relief can be used in both self-supporting and gliding applications. The vertical design enables easy scaling for individual chain widths. Different cables are inserted into the vertical rows, the system is closed and then screwed together at the top. Optional clips on the side sections connect the energy chain and strain relief. The system is currently under development for the 'e-chain E4.1L'.
Energy chains
Igus presents Vector Award
Every two years, igus presents the Vector Award, which recognizes "outstanding applications with energy chain systems". Out of 187 applications submitted from 30 countries, a company from Spain won the race for the golden Vector.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
