Gogatec
Enclosure light in aluminum housing
With the 'Gogaswitch LED A-1000', Gogatec offers a switch cabinet light in an aluminum housing that has a motion detector that switches off automatically after ten minutes.
© Gogatec
The switch cabinet light has a 3-pin through plug and a 16 A Schuko socket. The supply voltage is 210 to 240 V at 50/60 Hz. The 10 W LED module provides 1,000 lumens of light output with a light color of 4,000 K neutral white. Thanks to its compact design (400 mm x 60 mm x 40 mm), the luminaire can also be used where space is at a premium. The position does not matter, as two mounting brackets ensure a secure hold, which can be mounted both horizontally and vertically. The Gogatec luminaire operates at temperatures between -25 and +45 °C, complies with protection class IP20 and is CE, EMC and RoHS compliant (standard EN 55015 as of 2013).
In focus: Agriculture
The e-paper of issue 05/2024
Strategies for the future are one of the topics covered in the current issue of Computer&Automation. Read about the reforms that associations are demanding from politicians, the opportunities offered by technologies such as ChatGPT and SPE and...
The "living" e-paper
Screen Edition 2024
Welcome to the first issue of the 'Screen Edition', which opens up a completely new way of reading and informing yourself: With the Screen Edition, we offer you a dynamic and always up-to-date source of information with its finger on the pulse.
