ipf electronic at the SPS 2023
More light output for image processing
ipf electronic is expanding its range of additional camera lights with solutions featuring high-power LEDs: ER1Dxxx ring lights, ES46xxx spotlights and ES16xxx spotlights.
The high-power LEDs offer a light output of up to 16 W (ER1Dxxx) and focus the light with focusing lenses, resulting in a light emission angle of approx. 20° for the ring lights from ipf electronic and approx. 13° for the spot lights (ES46xxx). The ring lights in IP54 (optionally IP67) allow a maximum working distance of 750 mm and are available with white light (colour temperature 5000 K), unpolarized red light (wavelength 625 nm) and infrared light (wavelength 850 nm).
The spotlights in the ES46xxx series (56 mm x 45 mm x 46 mm) offer a light output of 9 W, are designed for a maximum working distance of 700 mm and also work with white light, red light and infrared light.
The spotlights in the ES16xxx series with a diameter of 16 mm have white light (color temperature 6020 K) and are available in two versions with 6 mm or 16 mm optics. The light from the LED with an output of 2 W can be focused or homogeneously blurred via the optics.
Hall 7A Stand 400
