Evotron
Multicolored area light
Evotron has introduced the 'A82x82' series of diffuse monochrome and multicolored surface lighting. New features have been added to the implemented 'Lumisens' technology.
© Evotron
Whereas previously only a single-channel controller could switch several ring light segments freely selectable and synchronized, different lighting wavelengths can now also be selected and controlled. In addition to the typical RGB configuration, standard LED wavelengths from deep blue to IR can be combined as required. Packaged in a robust IP64 aluminum housing (94 mm × 112 mm × 19 mm) with a Gorilla glass cover and illuminated area of 82 mm × 82 mmmm, the lighting from Evotron is connected to a constant current source with a standard four-pin M8 connector. In pulsed mode, the maximum light output is 40 W. Typical applications for the illumination are surface inspection with diffuse incident light, inspection of multi-colored measurement objects or precise measurement in transmitted light.
Basler
The long-standing Basler CEO Dr. Dietmar Ley will be leaving the company at the end of the year and will be succeeded by the current CCO/COO Hardy Mehl. The CTO position will be filled externally by Dr. Kai Jens Ströder.
