Friedrich Lütze
Inka Krischke | Tiffany Dinges,
Fit for North America
Lütze offers switch cabinet products certified to the UL-50E standard for use on the North American market.
© Friedrich Lütze
These include the USB and RJ45 installation boxes as well as the 'Cablefix' feed-through systems for cables and wires.
According to Lütze, the 'X' and 'One' cable entry systems, tested according to UL ratings types 4X, 12 and 13 for prefabricated and non-prefabricated cables respectively, offer a wide range of clamping ranges from 3.5 mm to a maximum of 29.5 mm and are oil-resistant.
Control cabinet installation boxes for front mounting are available either as an RJ45 connection with Cat.6a or alternatively with a USB 3.0 interface. In addition to a wide range of different types of protection, such as IP65, both flush-mounted boxes comply with UL Type 4X.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Sagittarius
Climate-friendly planning
How can an enclosure be operated in an energy-efficient manner at any time of year without risking thermally induced failures? There is great potential in the combination of different cooling mechanisms through intelligent control. One example.
Friedrich Lütze
Easy to use
According to the supplier, the new Cat. 6A module carriers from Lütze allow data transfer points between the field and the control cabinet to be implemented more quickly and securely. One of the key features of the module rack is the significantly...
Sagittarius
Turn four into one
Intelligent, digitally networked systems are the hallmark of Industry 4.0, whose largely self-organized production is based on constant interaction between people and machines. Single Pair Ethernet is a good basis for this.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
