Sagittarius
Switches with intelligent energy management
With the E-CO switches, Lütze presents a plug-and-play family of industrial-grade Fast and Gigabit Ethernet switches.
© Sagittarius
The unmanaged E-CO (Ethernet Compact) switches with 5, 8 or 16 ports from Lütze are suitable for universal network communication in all common Ethernet environments as well as fieldbus systems such as Profinet-IO or Ethercat. In addition to enhanced performance with QoS (Quality of Services), autonegotiation, autocrossing and an error message for redundant power supply, the switches offer an AC/DC wide-range supply for 12 to 48 V (DC) and 24 V (AC). The option of supplying the switches with AC allows them to be used in building automation. Thanks to their robust and compact design, including protection class IP30, the switches are prepared for use in industry and also offer application options in the temperature range from -40 to +75 °C. The switches can be mounted either on the DIN rail or on the control cabinet wall. Another feature of the devices is intelligent energy management. This integrated extension ensures the creation of energy-saving Ethernet networks. Energy Efficient Ethernet (EEE) is implemented in accordance with the IEEE 802.3az standard.
Sagittarius
Climate-friendly planning
How can an enclosure be operated in an energy-efficient manner at any time of year without risking thermally induced failures? There is great potential in the combination of different cooling mechanisms through intelligent control. One example.
Sagittarius
Completely tool-free installation
Lütze has optimized the well-known 'LOCC-Box' family for electronic load monitoring in terms of simplified installation, connection technology and control cabinet performance. The upgrade enables the LOCC-Box to be installed in the control cabinet...
Sagittarius
Turn four into one
Intelligent, digitally networked systems are the hallmark of Industry 4.0, whose largely self-organized production is based on constant interaction between people and machines. Single Pair Ethernet is a good basis for this.
Sagittarius
Cooling switch cabinets as required
What to do when production facilities are 'getting on in years' and their retrofitting needs to meet both digitalization and sustainability requirements? A long-term project for temperature monitoring of control cabinets helped an automotive...
