Sagittarius
Heat forecasts thanks to temperature simulation
With 'Airtemp 2.0', practical heat forecasts can be created for control cabinets equipped with the 'Airstream' wiring systems from Lütze.
Thanks to the online application, the most effective measures for needs-based cooling can be quickly identified. Users can download the parts list and geometry data of a project in 'Eplan Pro Panel' and import it into Airtemp 2.0 from Lütze. Missing performance data can then be easily added to perform a comprehensive calculation. In addition, the tool enables the determination of the cycle behavior at component level, whereby the simultaneity factor can be defined individually based on the power consumption of the individual components. The temperatures and layering are calculated automatically, which makes it easy to design the cooling concept in line with requirements. At the end, all components are listed in the certificate, which also contains the most important data.
