Hybrid connectors
Quelle: Hummel | Inka Krischke,
Adapted to the customer application
Single-cable solutions with hybrid connectors (One Cable Technology, OCT) reduce the complexity of cabling and save space and costs. Hummel has various hybrid solutions in its range and focuses on the requirements of the respective customer application.
© Bumblebee
The 'M23 Hybrid', for example, is a compact all-in-one solution with power processing up to 28 A/ 600 V and data transmission according to CAT 5e up to 500 Mbit/s. The 'M40 Hybrid' can transmit power up to 55 A and 600 V and process data in accordance with CAT 5e up to 500 Mbit/s. In addition, signal contacts can be operated with up to 300 V/ 7 A. The 'M16 (12+3)' connector is suitable for a current of up to 10 A and offers a data transmission rate of up to 100 Mbps. All of the supplier's hybrid connectors are suitable for harsh environments and offer comprehensive certifications and modularity. Housing designs, inserts and contacts can be combined within the respective connector series.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
