Automation systems
Quelle: LTI Motion | Inka Krischke,
Ethercat-based
With SystemOne CM (Compact Multiaxis), LTI Motion has launched a compact automation system onto the market.
© LTI Motion
It consists of the 'MotionOne CM' controller, the central power supply unit and the stackable 'ServoOne CM' multi-axis servo controllers, making it a scalable Ethercat-based automation system. Up to 18 A motor current plus triple overload are concealed in a servo controller that is only 55 mm wide. In the other sizes 2 to 4 (110 mm, 165 mm, 220 mm), the company offers a power spectrum of up to 210 A. Thanks to a separate controller for each axis, up to three motors can be operated with the multi-axis servo controller without compromising the control technology. The system thus covers motor currents from 3 to 210 A. In drive technology, an encoder cable is usually connected in parallel to each motor cable. When using the HDSL single-cable solution, the encoder cable can be omitted. The encoder signals are carried in two cores of the motor cable. The integrated controller with its scalable processor performance (Intel Atom with 1.3 GHz to Intel Core i3 with 2.2 GHz) is suitable for simple to highly demanding control tasks.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
