Geared motors
Drive design made easier
SEW-Eurodrive makes it easier for customers and interested parties to design geared motors with the help of the online tool 'Drive design'. The web application provides initial guidance on which geared motor may be suitable for the application in question.
It enables an initial design to get a feel for the required size. It can also be used to check how changed application data affects the load on the drive technology. The tool has an intuitive user interface. The specialist knowledge of an expert can be requested for advice at any stage. The 'Drive design' can be used directly without registration. The dynamic graphical structure of the tool means it can be used on mobile devices as well as desktop PCs. The online product design is based on the customer application. It includes a selection of classic applications such as hoists, carriages, turntables, roller conveyors, chain conveyors and goods conveyors in the field of intralogistics. The current motor series of IE3 asynchronous motors 'DRN..' in combination with the standard gear unit modular system from SEW-Eurodrive is taken into account. This includes helical, parallel shaft and worm gear units as well as bevel gear units and Spiroplan right-angle gear units. It enables an initial design to get a feel for the required size. It can also be used to check how changed application data affects the load on the drive technology. The tool has an intuitive user interface. The specialist knowledge of an expert can be requested for advice at any stage. The 'Drive design' can be used directly without registration. The dynamic graphical structure of the tool means it can be used on mobile devices as well as desktop PCs. The online product design is based on the customer application. It includes a selection of classic applications such as hoists, carriages, turntables, roller conveyors, chain conveyors and goods conveyors in the field of intralogistics. The current motor series of IE3 asynchronous motors 'DRN..' in combination with the standard gear unit modular system from SEW-Eurodrive is taken into account. This includes helical, parallel shaft and worm gear units as well as bevel gear units and Spiroplan right-angle gear units.
