Flow meter
Quelle: FlowVision | Inka Krischke,
Use in Ex zones 2, 21 and 22
FlowVision has added the FVone-EX-NP-CA to its ATEX product range. The compact flow meter works in Ex zones 2, 21 and 22 for measuring air, compressed air, nitrogen, oxygen, argon, carbon dioxide and methane.
© FlowVision
Among other things, two 0/4 to 20 mA analog outputs for flow and temperature measurement, a pulse output as a counter and two relay outputs for alarm signaling can be used for evaluation. The flow meter is configured using intuitive PC software via USB. There are three process connection variants to choose from: the classic screw-in variant with G1/2-inch thread, the push-in variant for sensor adapter 'TP' or ball valve 'BV' and the push-in variant for installation with compression fitting 'VK' or hygienic flange 'HEF'.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
