Flow meter
Use in Ex zones 2, 21 and 22
FlowVision has added the FVone-EX-NP-CA to its ATEX product range. The compact flow meter works in Ex zones 2, 21 and 22 for measuring air, compressed air, nitrogen, oxygen, argon, carbon dioxide and methane.
Among other things, two 0/4 to 20 mA analog outputs for flow and temperature measurement, a pulse output as a counter and two relay outputs for alarm signaling can be used for evaluation. The flow meter is configured using intuitive PC software via USB. There are three process connection variants to choose from: the classic screw-in variant with G1/2-inch thread, the push-in variant for sensor adapter 'TP' or ball valve 'BV' and the push-in variant for installation with compression fitting 'VK' or hygienic flange 'HEF'.
