Megatron
Magnetostrictive and contactless measuring principle
The robust displacement sensors of the OMS2 and PMS2 series from Megatron are insensitive to shock and vibration. Their magnetostrictive, contactless measuring principle ensures low-maintenance, wear-free operation.
© Megatron
The OMS2 series enables position detection in applications with measuring ranges from 50 to 1500 mm and the PMS2 series from 50 to 4000 mm. The mechanical detection of the linear movement is carried out via a guided or a free position encoder. The position of the magnetic encoder is output as a linear analog signal and is absolute. The position feedback is also immediately available after switching on and off.
The free encoder tolerates lateral and horizontal offsets of up to ±2 mm. According to Megatron, the magnetic encoder with ball coupling compensates for vertical and horizontal offset, which simplifies integration in applications with strong shock and vibration influences. The sensors are designed with IP67 protection.
TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
MTS Sensors
Powerlink version available
MTS Sensors is launching a Powerlink version of the 'Temposonics RSeries V' magnetostrictive position sensors for industrial applications, which were previously available with Profinet, Ethernet/IP and SSI outputs.
Balluff
Smart sensor technology for the IIoT
In addition to status information, intelligent sensors provide a wealth of secondary data - on service life, load level and damage detection as well as ambient temperature or contamination. Optical sensors in particular are undergoing a lot of...
