Posital
IP69K portfolio expanded
Posital has upgraded its portfolio of 'Ixarc' encoders and 'Tiltix' inclinometers with protection class IP69K.
© Posital
The IP69K range, which is designed for high-pressure jet cleaning at high temperatures
at high temperatures, has been equipped with a larger selection of different mechanical options and communication interfaces. Specifically, this involves more shaft diameters and flange types for the encoders.
The range of interfaces for encoders and inclinometers extends from analog, CANopen and J1939 to SSI, Modbus and IO-Link. Incremental encoders in IP69K design are also available with serial HTL/TTL interfaces. According to the supplier, the encoders in IP69k design are shock and vibration resistant and generally have robust stainless steel housings. Robust die-cast aluminum housings are used in particular for the IP-protected inclinometers.
TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
Captron
Working without 'pressure'
Safety switches based on capacitive buttons enable fatigue-free working. They can also be part of two-hand controls that prevent incorrect or inattentive operation with just one hand or another part of the body.
Baumer
A perfect fit in five steps
Laser distance sensors ensure process efficiency in automated production processes with the help of non-contact measurements. When choosing the right sensor, factors such as measuring range, focus, beam shape or object surface as well as ease of use...
MTS Sensors
Powerlink version available
MTS Sensors is launching a Powerlink version of the 'Temposonics RSeries V' magnetostrictive position sensors for industrial applications, which were previously available with Profinet, Ethernet/IP and SSI outputs.
Balluff
Smart sensor technology for the IIoT
In addition to status information, intelligent sensors provide a wealth of secondary data - on service life, load level and damage detection as well as ambient temperature or contamination. Optical sensors in particular are undergoing a lot of...
