Jola
Leakage detectors: problem fluids under control
Jola offers a sensor for leakage detection of highly electrically conductive problematic liquids such as antifreeze, liquid manure, silage leachate, acid, lye or salt solution in outdoor areas.
© Jola
The measuring principle is based on a temperature-compensated voltage divider, which means that harmless, electrically weakly conductive rainwater is ignored over a wide temperature range and does not trigger an alarm. The sensor is available in the STK-SPS4 version from the 'Jola-Leckwatcher' system. It is designed for operation with SELV or PELV safety extra-low voltage and has integrated galvanic isolation between the electrode, output and supply circuits.
The leakage detector is suitable for direct connection to PLCs, DDC controllers, fieldbus couplers, radio modules or similar automation technology components.
Siemens
The new products
This year's innovations from Siemens include the Sitrans MS Multisensor, which is used primarily for monitoring the condition of mechanical system components such as pumps, compressors, gearboxes and valves.
Baumer
Measured value is available in 15 s
The CombiLyz conductivity sensor from Baumer helps with the phase separation of food, water and cleaning liquids. It measures the electrical conductivity of the passing medium and draws conclusions about the type of medium and its concentration.
Current products
News about sensor technology
What would the smart factory of today and tomorrow be without sensors? Sensors are indispensable as the basis of every industrial production system. Computer&AUTOMATION has summarized current trends from spring 2017 in a picture gallery.
