Datalogic
Laser dot as aiming aid
With two auto-range devices, Datalogic now offers more flexibility for code reading in warehouse environments.
Both devices are based on a powerful LED lighting system.
© Datalogic
Both the PowerScan 95X1 hand-held scanner series and the Falcon X4 mobile computer are equipped with an auto-range function and therefore capture 1D and 2D codes from both long and short distances. As lighting conditions often vary in warehouse environments, both devices are based on a powerful LED illumination system that enables a reading distance of 15 cm to 20 m regardless of light influences.
The aiming device, which projects a rectangle with a central laser dot when reading from a short distance, also ensures ease of use. At long distances, this laser dot serves as an aiming aid. Both the mobile computer and the hand-held scanners from Datalogic are designed for harsh environments and can withstand repeated drops as well as water, dust and extreme temperatures.
Fraunhofer IPA
Calculated leakages
Using calculation to generate compressed air leaks in a system was an unusual requirement for the compressed air and pneumatics specialist Mader, which commissioned Fraunhofer IPA to visualize the effects of compressed air leaks live.
Endress+Hauser
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flow meter is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the supplier.
