Endress+Hauser
Inka Krischke | Tiffany Dinges,
Measuring gas made easy
The Prosonic Flow G300/500 ultrasonic flow meter is used for gas measurement. Thanks to the condensate-insensitive sensor design, the device delivers highly accurate measured values even with moist or wet gases, according to the supplier.
The Prosonic Flow G300/500 with integrated gas analysis function.
© Endress+Hauser
The integrated pressure and temperature measurement minimizes the installation effort, and the multi-parameter measurement allows both mass and standard volume to be measured and output directly. The integrated gas analysis function also makes it possible to calculate the calorific value, energy flow, molar mass, density and viscosity.
The flowmeter from Endress+Hauser is SIL-certified and, together with 'Heartbeat Technology', offers traceable device verification without interrupting the process.
Nivus
Flowmeter with IoT function
Nivus offers the 'Nivuflow' devices with a mobile radio modem with worldwide approval. The manufacturer's IoT concept allows the operator automatic data transmission in conjunction with many visualization and logging options.
