Posic
Kit for installation in confined spaces
Posic is expanding its product range with the IT5602C, a rotary encoder as an SMD component measuring 8 mm x 10 mm x 0.8 mm.
© Posic
Resolution and maximum speed are programmable up to 22 bits (1 million lines) or 8600 rpm. The output signals are A and B pulses in quadrature and an index pulse synchronized with the A and B edges.
Thanks to the eddy current measuring principle, the encoder is insensitive to interfering magnetic fields and is particularly suitable for integration in direct drives and applications in which magnetic fields or space conditions make the installation of conventional solutions difficult or impossible. Typical areas of application are industrial automation, robotics, mechanical engineering, laboratory automation and medical technology.
Would you like a little more?
First-hand news every week - that's what the Computer&AUTOMATION newsletter offers you.
© WEKA Trade Media
Subscribe to our newsletter and keep your finger on the pulse of automation. Stay up to date with us. We provide you with the latest news, exciting interviews, guest commentaries, application-oriented technical reports and new products.
Click here to subscribe.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
