Baumer
Bearingless, flexibly configurable encoder
Baumer is opening up new possibilities in drive technology with its 'LowHarmonics' encoder technology. The first product with this signal processing is the compact incremental magnetic ring encoder 'EB260'.
© Baumer
The bearingless encoder combines the precision of optical scanning with the robustness and cost-effectiveness of magnetic systems in a minimal installation space. The LowHarmonics signal processing with auto-calibration eliminates signal errors caused by mounting, temperature, ageing and mechanical factors, thus ensuring precision and control quality. The integrated airgap monitor continuously records the distance to the magnetic rotor. Even the smallest changes caused by damage to the machine mechanics are monitored and reported to the higher-level system. According to Baumer , the magnetic encoder is extremely robust thanks to its bearingless design and hermetically encapsulated electronics. It operates wear-free, does not heat itself up and is immune to shaft currents, strong impacts and shaft movements. It offers flexible shaft diameters and has an installation depth of 11 mm. Thanks to the intuitive 'Baumer Sensor Suite' software, a parameterizable motion monitor and switching output as well as square-wave, sine/cosine and IO-Link interfaces, the encoder is flexible in configuration.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Kübler at the SPS 2024
New generation of encoders
The 'Sendix' encoders have been an integral part of the Kübler product portfolio for many years. Now a new generation of encoders has been developed with state-of-the-art sensor and electronics technology that is suitable for integration into future...
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
