Lenord+Bauer
Space-saving rotor position encoder for confined installation situations
For applications where the installation space in electric drives is extremely limited, Lenord+Bauer offers an inductive rotor position sensor for detecting pole position, angle and speed with extremely small dimensions.
© Lenord+Bauer
According to Lenord+Bauer, the compact version of the well-known 'Variocoder' can be integrated into all motor designs in the smallest of spaces with high mounting tolerances. The rotor position encoder has a further reduced outer diameter, as the electronics housing is located directly on the stator. Users can choose between three different cable outlets: Axial, tangential and at an angle of 45°. This increases design freedom and enables better integration in tight installation spaces. The variable size concept is also retained in the compact version, so that the rotor position encoder can still be individually adapted to the customer's motor design.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Kübler at the SPS 2024
New generation of encoders
The 'Sendix' encoders have been an integral part of the Kübler product portfolio for many years. Now a new generation of encoders has been developed with state-of-the-art sensor and electronics technology that is suitable for integration into future...
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
