Kollmorgen Europe
Encoder offers multiturn absolute value position
Kollmorgen launches the 'SFD-M' (Smart Feedback Device, Multi-Turn) on the market. It provides machine builders with high-resolution multi-turn feedback with absolute position information that is available at system startup.
© Kollmorgen
The SFD-M absolute multiturn encoder was developed for 'AKD' and 'AKD2G' drives and can be integrated into servomotors with Kollmorgen housings at no extra cost. According to Kollmorgen, it offers multiturn performance, four times higher positioning accuracy and fifty times lower EMF noise than the absolute singleturn encoder 'SFD-3'. The encoder measures the position of the rotor shaft during each 360º revolution, without the need for a reference as a starting position, and records the total number of revolutions the shaft has traveled in both directions. This absolute multi-turn positioning capability is ideal for applications where precise position tracking is required over large rotational distances, such as machine tool positioning, packaging machines, material handling, satellite tracking and many other applications. In addition, the encoder retains absolute position information in real time even when the system is switched off, so that no time-consuming referencing sequences are required at start-up. In addition, the encoder uses energy harvesting technology to provide reliable position data without batteries or gears.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
Kübler at the SPS 2024
New generation of encoders
The 'Sendix' encoders have been an integral part of the Kübler product portfolio for many years. Now a new generation of encoders has been developed with state-of-the-art sensor and electronics technology that is suitable for integration into future...
Sick
Award for sustainability management
Sick has received a platinum medal in the EcoVadis sustainability ranking. This puts the provider of sensor-based automation solutions in the top 1 percent of more than 130,000 companies worldwide that have been assessed over the past twelve months.
