TWK Electronics
Certified for safety-related applications
The TRK38 safety encoder from TWK-Elektronik has been certified for applications that meet the requirements of SIL 2 (IEC 61508) and Performance Level d (EN 13849).
© TWK Electronics
The safety encoder from TWK-Elektronik detects speed and rotational speed and works according to the magnetic principle. The safety-related signals are transmitted via a certified Ethercat FSoE interface. Measuring 38 mm x 38 mm (diameter x length), the cylindrical sensor can also be installed in very confined spaces.
One of the first users of the singleturn absolute rotary encoder is a manufacturer of automated guided vehicles (AGVs) and mobile robots. Here, the encoder detects the rotation of the electric traction motor. Other areas of application for which the new safety sensor was developed include wind turbines (rotor position), crane systems (cable winch monitoring), filling systems and mobile machinery.
TWK
Safety encoder for AGVs
The TRK 38 from TWK is a compact and safety-oriented encoder for automated guided vehicles (AGVs) and mobile robots that helps them to navigate in space and move to target positions.
TWK
ATEX and SIL2/PLd certified
TWK has a safety encoder for explosion protection in accordance with ATEX, Zone 1/21. The new generation of encoders with Profinet interface (also with Profisafe profile) is also suitable for Zone 1 (gas) and 21 (dust).
TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
