TWK
ATEX and SIL2/PLd certified
TWK has a safety encoder for explosion protection in accordance with ATEX, Zone 1/21. The new generation of encoders with Profinet interface (also with Profisafe profile) is also suitable for Zone 1 (gas) and 21 (dust).
© TWK-ELEKTRONIK
The compact TWK enclosures made of aluminum or stainless steel with cable connection can be used without restriction in potentially explosive areas as ATEX Group II, Cat. 2, gas up to IIC and dust, as well as Group Dust IIIC devices. The certification applies to ATEX, IEC-Ex, North America Class 1/2 Div. 2 and EAC-Ex, among others.
The TRT78/S3 ATEX encoder with Profisafe interface offers functional safety (SIL2/PLd) and explosion protection for Zone 1. Explosion protection is achieved by a flameproof enclosure with special cable glands in which the electronics are inserted. It can withstand the explosion of a defective component. Neither sparks nor heated gases can escape through the openings. The housing also prevents the ingress of dust (IP6x). As the surface temperature of the enclosure does not exceed +100 °C, gas and any dust cannot ignite.
TWK
Safety encoder for AGVs
The TRK 38 from TWK is a compact and safety-oriented encoder for automated guided vehicles (AGVs) and mobile robots that helps them to navigate in space and move to target positions.
TWK
Detect alignment and speed simultaneously
TWK has expanded its family of inclination sensors with a special device that makes it possible to precisely measure the current orientation - i.e. the inclination or position (360°) - and the speed at the same time in a rotating application.
Electrosil
Dynamic haptic feedback
With the 'Smart-Knob Mini', Elektrosil is expanding its series of intelligent rotary pushbuttons with a compact solution. The rotary encoder combines rotation and pressure functionality in a robust housing with IP65 protection and a glass surface.
