Dold
Quelle: E. Dold & Söhne | Inka Krischke,
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine no longer emits a hazardous movement, the safety gate can be released directly when a standstill is detected.
© E. Dold & Sons
The standstill monitor can be easily retrofitted and is therefore also suitable for retrofitting. The absence of sensors or encoders makes installation simple. The standstill monitor fulfills SIL 3 or PL e/Cat. 4 and is used to release a solenoid interlock or activate a holding brake, for example on saws in woodworking, on machine tools or in conveyor technology.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
