Leuze
Safety in harsh environments
With the LBK radar system, Leuze is expanding its safety range with a safe 3D system for monitoring hazardous areas, even in environments with dirt, welding sparks, sawdust, smoke or moisture.
© Leuze
The system developed by Italian manufacturer Inxpect S.p.A. and distributed by Leuze safeguards hazardous areas near machines and systems. The radar system reacts to movements and generates a shutdown signal as soon as a person enters the monitored area. The 3D solution only interrupts operating processes if someone is actually present in the danger zone, thus avoiding unnecessary shutdowns. The radar technology used reliably distinguishes between people and static objects because it even detects people standing still in the protected area. Static objects such as pallets or material containers can even be left standing in the protected area; they do not cause the system to be interrupted.
The safe radar system is primarily used for restart protection and for monitoring areas that cannot be seen. Users can adapt it to their individual requirements by adjusting the number and position of the sensors, the adjustable range and the selectable opening angle. To secure larger rooms, up to six radar sensors can be interconnected via a controller.
Leuze
Sugar? Of course!
Südzucker has high quality standards - for the manufacturing process as well as for intralogistics processes. Safety aspects also play a key role - from retrieving the sugar sacks and buckets loaded on Euro pallets to loading the trucks.
Leuze
Identification made easy
With the stationary barcode reader 'BCL 200i', Leuze presents another member of the 'BCL' series. It supports guided container and tray identification and is particularly suitable for confined installation situations on the conveyor line.
Leuze
Two principles in one device
According to the manufacturer, the GSX combination fork sensor from Leuze combines the advantages of the light and ultrasonic versions and is particularly suitable for labeling machines in the packaging industry.
