Leuze electronic
Protection class IP67 accordingly
The 36 series sensors from Leuze are suitable for intralogistics, packaging technology and the automotive industry. They detect objects with different optical properties even at great distances, vibrations, ambient light or soiling.
Series 36 sensors from Leuze
© Leuze
The IP67-certified sensors from Leuze are available with different functional principles: as diffuse sensors with background suppression (up to 2.5 m range), as retro-reflective sensors (up to 17 m range) or as through-beam sensors (up to 80 m range). According to the supplier, the sensor design enables a very high function reserve, so that objects are reliably detected even if, for example, sources of interference are present. On request, users can also obtain the retro-reflective photoelectric sensors for detecting objects with depolarizing properties, such as foil-wrapped pallets. The sensors are available both with an M12 connection socket and with differently assembled connection cables.
Leuze
Sugar? Of course!
Südzucker has high quality standards - for the manufacturing process as well as for intralogistics processes. Safety aspects also play a key role - from retrieving the sugar sacks and buckets loaded on Euro pallets to loading the trucks.
