Door tumblers
Quelle: SSP Safety System Products | Inka Krischke,
Safety applications up to PLe
Fortress Interlocks is expanding its range of 'amGardPro' solenoid interlocks with the Slimline range of security interlocks and operating elements, which are now available in a narrow 40 mm wide version.
© SSP Safety System Products
The solenoid interlocks for robust applications can be adapted to customer requirements thanks to their modular design and solve safety applications up to PLe (EN/ISO 13849-1). Their configuration options range from control module, emergency release and emergency stop to signal lamp. The 'Extracted Key' function offers increased protection by removing personal safety keys: before maintenance personnel enter the system, the safety key must be removed and taken into the system. If the safety door is closed unintentionally, the system cannot be started without the key.
Mushroom
Erlkönige discovered
For the first time this year, Pilz gave all visitors to the SPS IPC Drives trade fair in Nuremberg a glimpse of the innovations of the coming years - we also took a look around!
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
