Safety analog input modules
Quelle: Bachmann electronic | Inka Krischke,
Measure temperature, pressure and flow rate
Bachmann electronic is launching the SAI205 safety module onto the market. According to the manufacturer, it offers extremely accurate measurement of external conditions such as temperature, mechanical stress, pressure and flow rate.
© Bachmann electronic
All data can be accessed for transfer to the cloud thanks to full integration into a SCADA system and remote access to all systems. The provider's safety solutions are modular and can be fully integrated into the 'M1' control system. With its four inputs for 4 to 20 mA signals, the module can analyze a range of safety-related variables from almost all standard 4 to 20 mA sensors, making it compatible with most sensors on the market. The four temperature inputs (Pt100) and two strain gauge inputs make it possible to record all relevant data for safe machine operation from one module.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
