OPC UA Server
Bachmann electronic,
Detects even critical values
Bachmann electronic presents a fully integrated ‚OPC UA Alarms & Conditions (A&C)‘ server for the M1 automation system.
© Bachmann electronic
Alarms and status information from the control and field level can be transferred from a PLC to other machines, operator panels, monitoring controls or ERP systems independently of the manufacturer or platform. The installable module detects critical values or status changes even without programming. In addition, the control logic can trigger alarm status changes from the control program via an API. All forwarded changes to operator panels, control consoles or A&C clients are secure and can be optionally encrypted. OEMs can transmit alarms to higher levels via the A&C server. This enables authorized operators to respond more quickly to changes at any level, with user actions visible on all networked systems. In addition, the ‚Atvise HMI‘ visualization software and ‚Atvise Scada‘ control console package fully support the OPC UA server.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
