Panel PCs
Quelle: Phoenix Contact | Lukas Dehling,
Windows 10 and new CPU
Phoenix Contact is equipping its Panel PCs in the Embeddedline family with the new Windows 10 Enterprise operating system. Alternatively, Windows Embedded Standard 7 is available.
© Phoenix Contact
If applications are not approved for this, the standard Windows 7 Professional operating system can be used. The Panel PCs with analog resistive touch display are also supplemented with additional functions: according to the manufacturer, a new Intel Atom E3845 quad-core processor is available as a powerful CPU in the entry-level range. A 2.5-inch SSD with 240 GByte should allow for demanding applications. Two galvanically isolated CAN interfaces are also available as an option. The device with a display size of 5.7 inches, which now expands the portfolio of Embeddedline PCs, is suitable for confined spaces.
MES solutions
Test the services
Energy chains
Lying flat on its side
