Human Machine Interfaces
Quelle: Mitsubishi Electric | Lukas Dehling,
IP67 thanks to adhesive protective film
The Open Frame GOT2000 HMI models from Mitsubishi Electric achieve protection class IP67 thanks to an adhesive protective film for the control panel on the front.
© Mitsubishi Electric
According to the manufacturer, they meet the high requirements for system equipment for hygienic production processes in the pharmaceutical and food industries. The front of the control panel is seamlessly integrated thanks to the flush-mounted installation. The design of the devices is intended to enable simple and flexible installation in the mounting cut-out. It can be adapted to various enclosure thicknesses between 1.5 mm and 4 mm. The edges of the control panel are protected with a profile strip to prevent possible damage to the HMI during installation. The device is suitable for data logging of PLCs and other devices, including the presentation of data in graphical or list form for easy analysis. The integrated web server function enables remote access to the HMI devices via PC from a standard web browser or status monitoring via the GOT mobile function using a smartphone or tablet. Security requirements are met with user identification and operating log functions.
MES solutions
Test the services
Energy chains
Lying flat on its side
Raspberry Pi
