Multimeter
RS Components | Inka Krischke,
Thermal imaging camera included
RS Components‘ RS-9889 thermal imaging multimeter allows you to detect thermal overload problems in electrical equipment from a safe distance without the need for physical contact.
© RS Components
The thermal imaging DMM is an all-in-one hand-held device that combines the features of a classic digital multimeter for measuring circuit parameters such as voltages, currents and resistances with those of an infrared thermal imaging camera. In this way, hot and cool points in electrical components can be identified on a visible thermogram. The thermal imaging camera offers maximum, minimum and mean crosshair alignment to help the user identify and measure the desired temperature ranges. A Bluetooth Low Energy (BLE) connection is used to quickly transfer thermal images to other devices via the Thermview+ app. The thermal imaging camera has a 2.8 inch TFT color LCD screen with an infrared resolution of 80 x 80 pixels. The thermal image multimeter also serves as a diode, resistance and continuity tester and is equipped with a buzzer for this purpose. The device can measure temperatures up to 1000 °C with a type K thermocouple sensor.
Dold
Standstill monitor: Easy to retrofit
The sensorless standstill monitor UG 6946 from Dold's 'Safemaster S' series has a width of 22.5 mm. If a machine is no longer moving in a dangerous direction, the safety gate can be released immediately when a standstill is detected.
Security Gateway
Data encryption via VPN
With Endian 4i Edge X from Endian, data from heterogeneous machine parks can be read out and displayed in dashboards for analysis. Remote maintenance and predictive maintenance can be implemented with the gateway.
Virtual HMI
Platform-independent remote access
Usually, the control of processes with a PLC runs fully automatically after the initial parameterization. In some applications, however, it is necessary for the operator or technician to be able to call up and set the process data at any time.
